Results 1 to 10 of 27
Thread: Waves in corners?
08-11-2015, 01:33 AM #1
Waves in corners?
Before I keep explaining the problem I would like to apologize if I called this issue wrong name. I am new to this and I hope you can correct me.
Maybe this is why I can't find it in forums or other places.
After every 90 degree corner my printer makes these tiny consistent and unnoticeable waves along walls. Its extra visible with the transparent blue PLA filament. You can barely see it but its there.
Is there anything I can do to solve this?
08-11-2015, 02:49 AM #2
- Burnley, UK
- 1,662
Slow down your print speed and acceleration settings if you have acceleration enabled. If you do not have acceleration enabled then enable it.
08-11-2015, 05:45 AM #3
08-12-2015, 11:59 PM #4
Acceleration is turned on in the front panel or with Rep G. Acceleration is tunable with Rep G when connnected via USB. Acceleration sounds like it speeds things up, however it actually controls how fast the mechanisms speed up and slow down. Those ripples are a common artifact of stopping too quickly and it makes the whole assembly shake. You can't see it with the naked eye. There are some good guides if you search for Sailfish documentation.
Another thing that also helps is to lessen the weight of the print head. If you find yourself printing mostly with only one extruder then it is good to remove one of the steppers and extruder/wiring. It's usually better to remove the left side since the right side is default and actuates the x motion position switch.
08-13-2015, 08:43 AM #5
another approach would be to say: It's barely noticeable - why worry about it ?
08-13-2015, 10:06 AM #6
I'd call that a little more than barely noticeable. Most likely though that could be sanded out pretty easily. I generally try to tune my acceleration so I an run at about 100mm/s with one stepper/extruder removed and have minimal corner defects.
08-14-2015, 05:26 AM #7
Corner ringing. See here for more info. Pay particular attention section 5.1.3.2
08-14-2015, 06:11 AM #8
pleased to say I've never had any of those issues in the pictures.
Either that or I just don't examine things with a magnifying glass and winge about it (lol)
If it works it's good. Hell even the stuff I print at 0.4 layer height looks better than those pics.
08-14-2015, 06:17 AM #9
- Burnley, UK
- 1,662
08-14-2015, 09:58 AM #10
- May 2014
- 35
Thanks Sebastian!
