Results 61 to 70 of 74
Thread: Free build plate!!!!
08-01-2015, 03:46 PM #61
08-03-2015, 08:40 PM #62
- Mar 2015
- Fenton, MI
- 63
I finally had the time to give it a go. I wasn't able to use it. The center was too high, I couldn't level the bed. I've put the plate on some spacers with weight on the middle, hoping to remove, or reverse the bow. If it's high on the edges I can clamp it down, but high in the middle, I can't do anything about that. I'm printing on glass right now.
08-04-2015, 04:22 AM #63
- Jun 2015
- 34
this issue did not happen on the smaller plates.
i am experimenting with stickyback magnetic film for the underside of the plates and for the printer bed.
im hoping this will fix that issue
08-04-2015, 06:33 AM #64
- Mar 2015
- Fenton, MI
- 63
Thanks for the reply diamond black. Here's my thoughts on the magnetic film.
1. Would the adhesive release due to heat?
2. That wouldn't help those with wood or plastic platforms.
Not criticisms at all, just thinking out loud. I'm looking forward to trying it, and I'll let you know my results if I can print on it.
08-04-2015, 07:06 AM #65
- Jun 2015
- 34
if you have any issues in printing on it then i could send out a magnetic bottom version if ok
08-09-2015, 09:05 PM #66
- Aug 2015
im using a fabrikator id love to try one 150mm x 150mm
08-11-2015, 06:36 PM #67
Sorry for the delay! I've been enjoying my Diamond Black build plate on my CraftBot. While I was skeptical of not using my bed heater I did not have bonding issues. The coarse texture allows the raft to dig in yet release with ease, far better than using Kapton or blue tape. With its flexibility, Diamond Black actually allows my prints to be removed easier than on my perforated build plate on my Zortrax M200. Attached are a few pictures of my first sample test. I will be testing Ninjaflex this evening and will follow up with my perceived pros and cons of the build plate.
11703432_526940260789310_314174905560566299_o.jpg11807594_526940267455976_2985169761556307723_o.jpg11834840_526940264122643_7489387240688067056_o.jpg
08-12-2015, 06:00 PM #68
- Jun 2015
- 34
thats great news. we are currently experimenting with magnetic bottoms and sticky back ferras sheet to eliminate the need for clamps or "screws" lol and to also fix the issue with larger plates slightly warping in the center. our first few tries look good. it will ad to the expense of the build plate and also add to the thickness, but it does make it really easy to use. just remove plate from bed then bend plate/remove part and place build plate back on bed. simples
also there is an issue with the material bubbling on the acrylic build plate. that is due to the heat which i believe expands any air underneath, we are using 3m adhesive now so that should eliminate that issue
if anyone could point out any other issue that would be helpfull thanx
08-12-2015, 06:02 PM #69
- Jun 2015
- 34
can i ask what filament you are using, pla,abs,pla
08-19-2015, 11:47 AM #70
So far I have printed with PLA and Ninjaflex. Pictures coming soon.
New member with print issue
