Results 1 to 10 of 17
07-25-2015, 10:29 PM #1
How to take out printed item from print bed?!
Just finished my first print out, but it stick on the print bed. @@
Any good method to take it out?!
Thx
07-26-2015, 12:17 AM #2
- Mar 2014
- 223
What is your print bed surface made off?
Normally I use a metal scrapper with a very thin edge to wedge to ply the part out, you just have to be careful not to scratch the print bed surface.
Also when I do my own designs, if I see the part could have sticking problems, I add printing pads around the bottom edges, basically circular pads about 0.5 or 0.6mm high that are easy to get a wedge under and then they help to lift the whole part off.
Simply adding a skirt around also helps to do that, but if the part is stuck good and hard the skirt will probably shear around the bottom edge without ever lifting the part; I suppose it would be possible to use a skirt more than one layer in height, two or three, to help with that.
Some time ago in the Slic3r subforum at the reprap forums I suggested an idea to have the option to create a pull-up tab when doing a skirt, like this:
The red represents the part being printed and the black the skirt plus the tab and ring to pull it off the print bed. It could be easy to create that as part of the stl too, but of course having it as an option in the slicing software would be more convenient.
I forgot to add, if your part is really stuck you may have to remove the print bed and give it a tap or two on the underside with a rubber hammer or something similar; depending on what your print bed is made of and how it is installed this method could go from being very easy and quick to a risky PITA... and all the stages in between.
07-26-2015, 04:33 AM #3
Detailed answer.
Different adhesion methods require different technique.
If it is a glass build plate, and use Kapton tape, hair spray or 3M blue tape for good adhesion,
you can heat the plate before removing the object, it will reduce much adhesion for easier taking off.
07-26-2015, 04:35 AM #4
- Jan 2015
- 306
07-26-2015, 08:42 AM #5
- Jan 2015
- 13
You can also turn canned air duster upside down to spray the liquid out and flash cool the part.
07-26-2015, 08:55 AM #6
My 3D printer is M3D with metal print bed. Anyway, I use the cutter to take it out......
07-27-2015, 02:12 AM #7
- Jul 2015
- 27
keep the plate heating, and use a shovel to remove it. The printer supplier should provide this tool along with the machine.
07-27-2015, 09:11 AM #8
07-28-2015, 12:27 AM #9
- Jul 2015
- 8
tape or a sharp razor scraper.
08-03-2015, 08:29 AM #10
with small parts I often hit them lightly with a hammer and that breaks the adhesion.
good job pla isn't brittle ;-)Last edited by curious aardvark; 08-03-2015 at 11:26 AM.
Printing time- Is this right?
