Results 1 to 10 of 10
07-24-2015, 10:10 AM #10
If you go dissolvable, HIPS is more compatible with ABS and higher temp filaments. PVA is hard to print with and only PLA will begin to stick to it. You might have better luck with the flex extruder. it will not work through a greg's style. Too squishy.
New member with print issue
