Originally Posted by
mikes1098
Maxborg did you ever figure out a fix? I am running windows 8.1 64bit and am getting the same error when I try to export the file. It crashes every time. I also get the same error if I click "add file" however if I simply drag the file into the window the error does not occur.
I will try uninstalling and reinstalling later today. If that does not work I might try installing 3.6....unless there are other ideas.
Thanks
Mike
