Results 11 to 16 of 16
06-26-2015, 08:50 AM #11
- Jun 2015
- 11
Well, after stretching the spring, i have not yet had one failed print from the original issue. Guess that was it. Anyone have any links for a good aluminum extruder? Preferably one that uses a spring, but also has a tension screw. And also uses the original feed gear/cog.
06-26-2015, 09:16 AM #12
06-26-2015, 11:42 AM #13
- Jun 2015
I am experiencing the same problem. We have 2 replicator2 machines. Both will successfully start a print but stop pat way through. The printer head stops extruding but continues to go through the motions. These are parts from a file I have use successfully in the past a number of times. I am printing PLA at 230C. It appears that at some point the pla is getting stuck in the feeder tube that screws into the heater block. Yesterday I dismantled the head. Cleared out the feeder tube and the extruder tip. Readjusted the build plate. The print started beautifully but stopped after 3mm had been put down. This was a 16 hr print. It was running around in the air when I came in this morning.
Puzzling and pretty frustrating.
06-30-2015, 09:53 AM #14
- Jun 2015
- 11
06-30-2015, 09:54 AM #15
- Jun 2015
- 11
08-19-2015, 07:54 AM #16
- Mar 2015
