Results 1 to 10 of 16
Thread: Issues with prints
06-03-2015, 07:48 AM #1
Issues with prints
Good Morning All!
OK so I posted here before about my issue with corners rounding. I have made adjustments and still have the issue. Here is what I have done:
tightened belts aswell as added belt tensionors
Slowed jerk down to 15
Slowed acceleration down to 500
Printing at 30mm/s
I am at a loss on what to do. I have attached two photos showing what is happening.
06-03-2015, 08:55 AM #2
What size filament , what temp and extrusion multiplier are you using?
06-03-2015, 09:02 AM #3
I am using 1.75 filament, at 210, with a .92 multiplier
06-03-2015, 09:03 AM #4
I also use a cooling fan that is on all the time
06-03-2015, 09:48 AM #5
Try setting your:
Nozzle Diameter to :.35
Extrusion Multiplier: .90
Extrusion Width : .40
Turn off fan just to test..
Make sure your retraction settings are set as well.
06-03-2015, 10:00 AM #6
Just to be clear, I should set my nozzle diameter to .35 (.05 smaller then what I have)? What do you recommend for the retraction settings? I believe I have that set to 5mm I would have to check
06-03-2015, 10:11 AM #7
yes, set it a bit smaller...retraction settings depend on your setup...I use E3d 1.75. My retraction is set to 2mm at 15mm/sec.
06-03-2015, 10:30 AM #8
Great! I will input these settings, and give it a shot tonight. I will report back with my findings. Thank you Voodoo for your help!
06-03-2015, 12:47 PM #9
- Feb 2015
- Miami
- 12
06-03-2015, 01:10 PM #10
It will eliminate the back and forth filling between two thin walls..
I saw this on a video from 3d Hangouts..
see here for better explanation: https://youtu.be/grRQ8MWkf0A?t=26m
