Results 11 to 16 of 16
Thread: Replacing Hexagon with E3Dv6
04-28-2015, 09:14 AM #11
- Jan 2015
- 68
04-28-2015, 09:40 AM #12
i used the regular hexagon plate with a washer like the ones that came with the hobbed bolt as a shim between the hotend and extrduer block..worked perfectly too.
OR
You can go this route...I modified Clough42 Itty Bitty Single Extruder to work with the E3d V6 3mm and the stock Hexagon Plate.
http://www.thingiverse.com/thing:714547
04-28-2015, 09:56 AM #13
- Jan 2015
- 68
05-04-2015, 09:29 AM #14
- Jan 2015
- 68
Just an update for anyone who is interested. The e3d installed perfectly into the stock extruder from makerfarm. I did end up using the new mounting plate that I ordered at the same time as the hot end.
06-02-2015, 11:35 PM #15
- Feb 2015
- 371
I don't know how I missed this, but the ABL foot from 42 is too short! Anyone got an STL that will work with the ED3, it is longer than the hexagon.
06-03-2015, 06:03 AM #16
- Nov 2014
- 138
