Results 1 to 10 of 10
Thread: Auto bed leveling oddities
06-01-2015, 01:33 PM #1
- Feb 2015
- 211
I notice that when I use complete auto bed leveling I often have issues with the first layer being stuck well in some areas and not enough in others.
If I take the exact same Gcode and remove the G29 so it doesn't map the bed the first layer prints fine without making any changes anywhere. I have leveled the bed manually with feeler gauges and it is pretty level.
Just wondering if anyone else notices this and has any idea what could be causing it?
My first thought would be inconsistent z-probe, I have seen where people have had actual position data from the bed mapping process. What is the easiest way to get the individual position data from the bed mapping?
Thanks,
Chadd
06-01-2015, 02:49 PM #2
Where did you get your Marlin code? If you have the Enhanced G29 code you just issue a G29 V4 to get all the position data. And you might want to check if you have the M48 command. That will test the accuracy (repeatability) of your probe and axis hardware.
Usually, when you have issues with the first layer going down nicely with Auto Bed Leveling, it is because you are not sampling enough points. Some people swear by the 3-Point leveling, but my experience is when you get too far from a sample point, the nozzle is the wrong distance from the glass. Doing a 4 x 4 Grid usually cures that problem.
06-01-2015, 03:56 PM #3
- Feb 2015
- 211
This FW was from not too long ago when the thread was going on about ABL with the RUMBA board. I am sampling 9 points on the bed. The odd thing is that it is always toward the center of the bed that the first layer is not pressed down far enough when I use G29.
Thanks for the tips, I have a few things printing right now but will try your suggestions as soon as they are finished up .
06-01-2015, 05:14 PM #4
06-01-2015, 09:56 PM #5
- Feb 2015
- 211
Here are the results of the G29 n 5 T
SENT: G29 n 5 T
RECEIVED: Eqn coefficients: a: 0.00 b: 0.00 d: 0.62
RECEIVED:
RECEIVED: Bed Height Topography:
RECEIVED: --0.00246 +0.01879 +0.02154 +0.01879 --0.01421
RECEIVED: --0.07346 +0.02904 +0.05879 +0.04304 --0.03171
RECEIVED: --0.11346 --0.01746 +0.02329 +0.03054 --0.02171
RECEIVED: --0.11571 --0.01196 +0.05629 +0.06604 +0.02254
RECEIVED: --0.08946 --0.03571 +0.00804 +0.05879 +0.07179
RECEIVED:
RECEIVED: planeNormal x: -0.00 y: -0.00 z: 1.00
RECEIVED:
RECEIVED:
RECEIVED: Bed Level Correction Matrix:
RECEIVED: 1.000000 0.000000 0.000353
RECEIVED: -0.000000 1.000000 0.000021
RECEIVED: -0.000353 -0.000021 1.000000
RECEIVED: ok
RECEIVED: echo:endstops hit: Z:0.66
06-01-2015, 10:05 PM #6
- Feb 2015
- 211
Here are the results of the M48
SENT: M48
RECEIVED: M48 Z-Probe Repeatability test. Version 2.00
RECEIVED: Full support at: http://3dprintboard.com/forum.php
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED: Mean: 0.719800
RECEIVED: Standard Deviation: 0.001030
RECEIVED:
RECEIVED: ok
RECEIVED: echo:endstops hit: Z:0.72
06-01-2015, 11:09 PM #7
06-02-2015, 12:03 AM #8
- Feb 2015
- 211
06-02-2015, 07:54 AM #9
If your bed was perfectly level, the correction matrix will be a diagonal matrix of 1's (with 0's every where else). But as it has to correct for issues you will see the numbers get bigger and bigger (from 0) and the diagonal will shrink from 1's to .9 What is really happening is the matrix [X,Y,Z] is being multiplied by the correction matrix to produce the new coordinates [X',Y',Z']. If everything is perfect the X number gets multiplied by 1 and no Y or Z component (because it is 0) gets added to the new X' number. But as the bed gets tilted, X' is equal to X*.99 + Y*.001 + Z*.001 (or how ever your bed is tilted).
06-05-2015, 07:03 PM #10
- Jan 2015
- 68
Never mind, i switched to Repetier firmware
