Results 1 to 10 of 11
Thread: MakerFarm I3V STL???
05-31-2015, 08:13 PM #1
- Apr 2015
- Lakeport, CA.
- 174
Does MakerFarm make available STL (or anything importable into FreeCAD) for components of their I3V kits?
I need to make a small mod to the X carriage assy.
I'm adding the inductive sensor for ABL, and would like to do it "nicely". There is an OpenSCAD design up on thingiverse, and it's a possibility, just didn't want to mess w/ OpenSCAD just yet.
I assume the parts for the X carriage are the same for the 8"-12" models...
Thx!
06-01-2015, 12:31 AM #2
- Nov 2014
- 522
ther eis not an STL, but you can find and download the laser burn files...
06-01-2015, 12:43 AM #3
- Apr 2015
- Lakeport, CA.
- 174
06-01-2015, 07:04 AM #4
You can use this file..
06-01-2015, 07:20 AM #5
- Nov 2014
- Brevard, NC
- 182
Here is a plastic version of it you can print or modify the openscad file. http://www.thingiverse.com/thing:610967
06-02-2015, 06:36 PM #6
- Apr 2015
- Lakeport, CA.
- 174
Voodoo: Thx. The site seems to have a problem with attachments at the moment, but will try again periodically.
Pyramid: Ditto the thx. I've downloaded it and started playing with it a bit. It's tempting to use it as a way to build all the mods into a single piece, but after my little experiment, it's clear I'm gonna have to upgrade my CAD skills a bit more.
What I tried was merging the x-carriage shelf from clough42's HE cooling solution for the hexagon into this x-carriage.
Clough42's model is in STL and SolidWorks..., and the X-carriage model is provided as STL and SCAD.
I imported both STL into FreeCAD and worked with that. Various details remained before I came to the conclusion that making the thing printable was gonna be a problem I didn't really want to mess with.
So..., in the interim, the upgrades are gonna happen using the MF x-carriage (which is what they're designed for anyway)..., and longer term, gonna put some time into learning OpenSCAD and then try something a little sexier.
06-02-2015, 07:10 PM #7
People... 3DPrintBoard has been broken as far as attachments since early April. No one at the helm seems to care, so we apparently have to live with it. Some images seem to post OK, but for anything else, you're best off pushing them to something like pastebin or dropbox and then linking to those in your posts.
If you care to voice an opinion to 3DPrintBoard, I recommend adding to one of the existing threads or create a new thread in the site discussion area, or perhaps mention it in the chat box. I personally believe that until enough people complain at the upper level of the 3DPrintBoard structure, we'll continue to get no attention or any kind of response from the admins. I have politely PM'd the admins I am aware of and have received zero response.
UNTIL THINGS ARE FIXED: If you provide an attachment, ALWAYS attempt to view it yourself after posting it to make sure it opens OK. If you want to link to an old thread that you knew had good content, ALWAYS go back and look at it first to make sure the link is still worth it with the inevitable missing images and attachments.Last edited by printbus; 06-02-2015 at 08:09 PM.
06-02-2015, 07:41 PM #8
06-02-2015, 08:11 PM #9
06-02-2015, 08:53 PM #10
I know its not as good as a board, but we can use the makerfarm group over at thingiverse.. http://www.thingiverse.com/groups/makerfarm-i3v/topics
