Results 1 to 9 of 9
  1. #1
    Best way to level threaded thermal tube nozzles?
    Anyone here with threaded thermal tubes? I have my nozzles pretty close by pure luck but I want to get them perfectly level and I have all metal extruder with threaded thermal tubes not set screws. Just wondering if there's an easy way to do it?
  2. #2
    Technician
    Apr 2015
    Location
    State of Confusion
    Add Nargg on Thingiverse
  3. #3
    Again, mine has threaded thermal tube and threaded cooling bar, not set screws so this video is no help. With the set screw version its ago easy to align I don't even have to take it apart, just loosen them up and let the nozzles fall onto the platform. I can't do that though, I have to screw the tubes in.
  4. #4
    Senior Engineer
    Jun 2014
    Location
    Burnley, UK
    I used soft (ish) springy, compressible washers between the aluminium and the carriage so that tightening and slackening the two mounting bolts would cant the aluminium bar slightly. With a dial gauge on the bed pointing up and moving the head over the gauge it is possible to get them very close.
    FYI, a difference of 0.0008 inches on a Stratasys is considered to need adjustment. This is only relevant if you are doing prints with both extruders at the same time though they do need to be pretty close particularly if you are printing tall things as when printing with the higher one the lower one will knock over whatever you are printing.
  5. #5
    Jul 2014
    You sure you're using a flashforge ?
  6. #6
    Engineer-in-Training ServiceXp's Avatar
    Apr 2015
    Location
    USA
    Follow ServiceXp On Twitter Add ServiceXp on Google+ Add ServiceXp on Thingiverse
    That is exactly what I was thinking, I've not seen any reference to a stock FF having threaded thermal tubes.
  7. #7
    Apr 2015
    Location
    Northern Ohio
    Quote Originally Posted by Mjolinor View Post
    This is what I would do. I do agree with the others that you probably are not using a FF printer.
  8. #8
    Technician
    Dec 2014
    Good idea. What I did was to place a small paper washer the thickness of the difference under the high side screw
  9. #9
    It has the alu-dual cooling bar and threaded thermal barrier upgrade, that's why I asked if anyone has threaded thermal barriers. I think I'm going to build some kind of bracket to help me align them.
