Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    One Last Question For a While.....
    Is there a way to turn off the light? LOL
    Thanks in advance!
  2. #2
    Super Moderator
    Apr 2014
    Location
    KS
    Add jfkansas on Thingiverse
    Probably can unplug it. I think you can disable in the front panel options also.
  3. #3
    Engineer-in-Training
    Apr 2015
    Location
    Northern Ohio
    insert a line in the g code file containing this M146 r0 g0 b0 That will turn the lights off.
  4. #4
    Thanks Todd!
  5. #5
    Jul 2014
    yep lights are in the front panel settings. On/off colour settings etc
    I don't have them on the flashforge - but love them on the Klic-n-print.
    Why would you want to switch them off ?
  6. #6
    Apr 2015
    Location
    Northern Ohio
    Quote Originally Posted by The Grey's Studios View Post
    Thanks Todd!
    The M146 command can be used to adjust color as well. I have mine set up for red while heating up, White while printing and green when the print is done. It serves no purpose other than amusement.
  7. #7
    For over night printing of long jobs. I have the printer in my bedroom/ home office. That is the main reason. I have a room divider too, but it doesn't really cut down the glow from them. Thank you - like how you can change their colors too!
  8. #8
    Apr 2015
    Location
    Northern Ohio
    Ah... That makes sense. I run mine overnight all the time but I could not take the noise when I was trying to sleep in the same room.
  9. #9
    Engineer
    Oct 2014
    Quote Originally Posted by Todd-67 View Post
    Pretty cool did not know that. Do you know the code's for keeping it certain color's while printing?
  10. #10
    Apr 2015
    Location
    Northern Ohio
    Quote Originally Posted by Bassna View Post
    The M146 command addresses the lights. The RGB values are adjusted from 0 to 255. For example M146 R255 B0 G0 would be a red light and M146 R0 B255 G0 would be blue. If you wanted purple it would be a mix of red and blue such as M146 R225 B225 G0.
    Depending on what slicer you are using you can put the color change sequences at certain intervals such as pre-heat, print and post print.
