Results 1 to 9 of 9
Thread: Resin fillers, your ideas.
05-20-2015, 03:23 PM #1
- May 2015
- 43
Hi all.
I know it's early days, but as it's rather quiet around here I thought I start a thread.
A few things mentioned on these forums and others were:
- Rice (still not sure about this one )
- Micro glass beads
- Corn flour
What ideas do others have?
05-20-2015, 10:31 PM #2
- Sep 2013
- 308
I think if uv resin were to be used with beads as a filler, then beeds that pass uv light would be best, to help uv light penetrate deep into the print.
Im quite sure printing shells and filling them after is the best way to get fast prints that are solid, so I think fillers will become important soon
05-21-2015, 01:57 AM #3
- Feb 2014
- 36
05-21-2015, 03:36 AM #4
- nsw australia
- 81
just did a quick google on density of aluminium, and it is 2.7 TONNES per cubic METRE, as fresh water is only 1 TONNE per cubic metre, you would have to ADD a hell of a lot of salt to the water to get the water to similar density(probably beyond the max carrying capacity of water)
05-21-2015, 03:47 AM #5
- Feb 2014
- 36
It begs the question - is there any other (very heavy) liquid we could use instead of brine?
05-21-2015, 04:13 AM #6
- Feb 2014
- 36
Hey, Rylan, could we use Soduim polytungstate? it has a maximum attainable solution density of 3,1 g/cm3 at 25°C and would allow us to use aluminum powder as filling. perhaps some alloys?
05-21-2015, 12:36 PM #7
- May 2015
- 43
05-22-2015, 01:56 PM #8
- Sep 2013
- 308
Wow just read up on this Sodium polytungstate http://en.wikipedia.org/wiki/Sodium_polytungstate
That looks really promising we should try that!
looks like since its very reusable its ok if its a bit expensive:
http://geoliquids.com/product-catego...based-product/
A New Thread is a good idea to but Ill let you start it.
05-22-2015, 04:20 PM #9
- 41
Probably would be really cool to add partially cured latex microparticles, which when combined with the acrylic resin would form a tougher material overall and less brittle. Even add a third component would be interesting for adding and tuning the properties of the final part.
