Results 1 to 8 of 8
05-17-2015, 04:45 PM #1
- Jul 2014
- 305
What do you use to lube your threaded rod?
I have been printing on the machine for at least 10 hours now and want to lube the threaded rod. What can I purchase at Home Depot/Lowes/Ace that would work?
05-17-2015, 08:50 PM #2
- Nov 2014
- 522
i use 4 in 1 oil or whatever thats called... just the general oil available at lowes
05-17-2015, 10:09 PM #3
- Jul 2014
- Eastern Colorado
- 536
Sometimes Liquid Wrench Penetrating Oil.
Sometimes 3-in-One Multi-Purpose Oil.
Sometimes DuPont Teflon Multi-Use Lubricant.
Whichever one is in sight and reach when my threaded rods start squeaking.
05-18-2015, 07:01 AM #4
- Jan 2015
- 68
I used Rem Oil (Remington Gun Oil) or Slip2000 (gun grease). You can find the Rem oil at any outdoors store, but the slip 2000 you will need to get online.
05-18-2015, 08:56 AM #5
Also good to avoid spraying hairspray on the rods. it's basically anti-lube. (ask me how I know)
05-18-2015, 10:25 AM #6
I found and use sewing machine oil, which is probably the same as the 4 in 1 oil I think.
05-18-2015, 05:56 PM #7
- Nov 2014
- Brevard, NC
- 182
I use bearing packing grease from an auto parts store. It is inexpensive & will probably last me forever. This is what someone recommended I use awhile back. It is a little messy, but seems to work well & have not had to put it on very often.
05-18-2015, 06:41 PM #8
- Jul 2014
- 305
Thank you! I purchased some 3 in one and applied it.
