Results 1 to 10 of 68
05-13-2015, 08:20 PM #17
You are most welcome.
Try this:
Code:case 48: // M48 Z-Probe repeatability { #if Z_MIN_PIN == -1 #error "You must have a Z_MIN endstop in order to enable calculation of Z-Probe repeatability." #endif double sum=0.0; double mean=0.0; double sigma=0.0; double sample_set[50]; int verbose_level=1, n=0, j, n_samples = 10, n_legs=0, engage_probe_for_each_reading=0 ; double X_current, Y_current, Z_current; double X_probe_location, Y_probe_location, Z_start_location, ext_position; if (code_seen('V') || code_seen('v')) { verbose_level = code_value(); if (verbose_level<0 || verbose_level>4 ) { SERIAL_PROTOCOLPGM("?Verbose Level not plausable.\n"); goto Sigma_Exit; } } if (verbose_level > 0) SERIAL_PROTOCOLPGM("M48 Z-Probe Repeatability test. Version 1.85\n"); if (code_seen('n')) { n_samples = code_value(); if (n_samples<4 || n_samples>50 ) { SERIAL_PROTOCOLPGM("?Specified sample size not plausable.\n"); goto Sigma_Exit; } } X_current = X_probe_location = st_get_position_mm(X_AXIS); Y_current = Y_probe_location = st_get_position_mm(Y_AXIS); Z_current = st_get_position_mm(Z_AXIS); Z_start_location = st_get_position_mm(Z_AXIS) + Z_RAISE_BEFORE_PROBING; ext_position = st_get_position_mm(E_AXIS); if (code_seen('E') || code_seen('e') ) engage_probe_for_each_reading++; if (code_seen('X') || code_seen('x') ) { X_probe_location = code_value() - X_PROBE_OFFSET_FROM_EXTRUDER; if (X_probe_location<X_MIN_POS || X_probe_location>X_MAX_POS ) { SERIAL_PROTOCOLPGM("?Specified X position out of range.\n"); goto Sigma_Exit; } } if (code_seen('Y') || code_seen('y') ) { Y_probe_location = code_value() - Y_PROBE_OFFSET_FROM_EXTRUDER; if (Y_probe_location<Y_MIN_POS || Y_probe_location>Y_MAX_POS ) { SERIAL_PROTOCOLPGM("?Specified Y position out of range.\n"); goto Sigma_Exit; } } if (code_seen('L') || code_seen('l') ) { n_legs = code_value(); if ( n_legs==1 ) n_legs = 2; if ( n_legs<0 || n_legs>15 ) { SERIAL_PROTOCOLPGM("?Specified number of legs in movement not plausable.\n"); goto Sigma_Exit; } } // // Do all the preliminary setup work. First raise the probe. // st_synchronize(); plan_bed_level_matrix.set_to_identity(); plan_buffer_line( X_current, Y_current, Z_start_location, ext_position, homing_feedrate[Z_AXIS]/60, active_extruder); st_synchronize(); // // Now get everything to the specified probe point So we can safely do a probe to // get us close to the bed. If the Z-Axis is far from the bed, we don't want to // use that as a starting point for each probe. // if (verbose_level > 2) SERIAL_PROTOCOL("Positioning probe for the test.\n"); plan_buffer_line( X_probe_location, Y_probe_location, Z_start_location, ext_position, homing_feedrate[X_AXIS]/60, active_extruder); st_synchronize(); current_position[X_AXIS] = X_current = st_get_position_mm(X_AXIS); current_position[Y_AXIS] = Y_current = st_get_position_mm(Y_AXIS); current_position[Z_AXIS] = Z_current = st_get_position_mm(Z_AXIS); current_position[E_AXIS] = ext_position = st_get_position_mm(E_AXIS); // // OK, do the inital probe to get us close to the bed. // Then retrace the right amount and use that in subsequent probes // engage_z_probe(); setup_for_endstop_move(); run_z_probe(); current_position[Z_AXIS] = Z_current = st_get_position_mm(Z_AXIS); Z_start_location = st_get_position_mm(Z_AXIS) + Z_RAISE_BEFORE_PROBING; plan_buffer_line( X_probe_location, Y_probe_location, Z_start_location, ext_position, homing_feedrate[X_AXIS]/60, active_extruder); st_synchronize(); current_position[Z_AXIS] = Z_current = st_get_position_mm(Z_AXIS); if (engage_probe_for_each_reading) retract_z_probe(); for( n=0; n<n_samples; n++) { do_blocking_move_to( X_probe_location, Y_probe_location, Z_start_location); // Make sure we are at the probe location if ( n_legs) { double radius=0.0, theta=0.0, x_sweep, y_sweep; int rotational_direction, l; rotational_direction = (unsigned long) millis() & 0x0001; // clockwise or counter clockwise radius = (unsigned long) millis() % (long) (X_MAX_LENGTH/4); // limit how far out to go theta = (float) ((unsigned long) millis() % (long) 360) / (360./(2*3.1415926)); // turn into radians //SERIAL_ECHOPAIR("starting radius: ",radius); //SERIAL_ECHOPAIR(" theta: ",theta); //SERIAL_ECHOPAIR(" direction: ",rotational_direction); //SERIAL_PROTOCOLLNPGM(""); for( l=0; l<n_legs-1; l++) { if (rotational_direction==1) theta += (float) ((unsigned long) millis() % (long) 20) / (360.0/(2*3.1415926)); // turn into radians else theta -= (float) ((unsigned long) millis() % (long) 20) / (360.0/(2*3.1415926)); // turn into radians radius += (float) ( ((long) ((unsigned long) millis() % (long) 10)) - 5); if ( radius<0.0 ) radius = -radius; X_current = X_probe_location + cos(theta) * radius; Y_current = Y_probe_location + sin(theta) * radius; if ( X_current<X_MIN_POS) // Make sure our X & Y are sane X_current = X_MIN_POS; if ( X_current>X_MAX_POS) X_current = X_MAX_POS; if ( Y_current<Y_MIN_POS) // Make sure our X & Y are sane Y_current = Y_MIN_POS; if ( Y_current>Y_MAX_POS) Y_current = Y_MAX_POS; if (verbose_level>3 ) { SERIAL_ECHOPAIR("x: ", X_current); SERIAL_ECHOPAIR("y: ", Y_current); SERIAL_PROTOCOLLNPGM(""); } do_blocking_move_to( X_current, Y_current, Z_current ); } do_blocking_move_to( X_probe_location, Y_probe_location, Z_start_location); // Go back to the probe location } if (engage_probe_for_each_reading) { engage_z_probe(); delay(1000); } setup_for_endstop_move(); run_z_probe(); sample_set[n] = current_position[Z_AXIS]; // // Get the current mean for the data points we have so far // sum=0.0; for( j=0; j<=n; j++) { sum = sum + sample_set[j]; } mean = sum / (double (n+1)); // // Now, use that mean to calculate the standard deviation for the // data points we have so far // sum=0.0; for( j=0; j<=n; j++) { sum = sum + (sample_set[j]-mean) * (sample_set[j]-mean); } sigma = sqrt( sum / (double (n+1)) ); if (verbose_level > 1) { SERIAL_PROTOCOL(n+1); SERIAL_PROTOCOL(" of "); SERIAL_PROTOCOL(n_samples); SERIAL_PROTOCOLPGM(" z: "); SERIAL_PROTOCOL_F(current_position[Z_AXIS], 6); } if (verbose_level > 2) { SERIAL_PROTOCOL(" mean: "); SERIAL_PROTOCOL_F(mean,6); SERIAL_PROTOCOL(" sigma: "); SERIAL_PROTOCOL_F(sigma,6); } if (verbose_level > 0) SERIAL_PROTOCOLPGM("\n"); plan_buffer_line( X_probe_location, Y_probe_location, Z_start_location, current_position[E_AXIS], homing_feedrate[Z_AXIS]/60, active_extruder); st_synchronize(); if (engage_probe_for_each_reading) { retract_z_probe(); delay(1000); } } retract_z_probe(); delay(1000); clean_up_after_endstop_move(); // enable_endstops(true); if (verbose_level > 0) { SERIAL_PROTOCOLPGM("Mean: "); SERIAL_PROTOCOL_F(mean, 6); SERIAL_PROTOCOLPGM("\n"); } SERIAL_PROTOCOLPGM("Standard Deviation: "); SERIAL_PROTOCOL_F(sigma, 6); SERIAL_PROTOCOLPGM("\n\n"); Sigma_Exit: break; } #endif // ENABLE_AUTO_BED_LEVELING
