Results 11 to 15 of 15
05-05-2015, 07:33 AM #11
the lid - unless you've inverted it, will print much much better with the top flat on the print platform. And wouldn't need supports.
One of the problems I see round here is people assuming that they have to use supports for everything. When correct design and orientation can often eliminate them entirely.
05-06-2015, 03:42 AM #12
- Mar 2015
- 18
I initially tried to print flat bottom up - as you said it should print much better but still had the issues seen in earlier images read a hole in the middle.
Definitely the model and not print settings as per defaults and dozens of variations. Different printers confirm this.
05-06-2015, 03:43 AM #13
- Mar 2015
- 18
Lid and Pot.zip
Newer files
05-06-2015, 03:09 PM #14
- May 2014
- hiding in your pillow
- 52
05-07-2015, 06:43 AM #15
- Mar 2015
- 18
Progress
Wall thickness at center measured at 0.31mmThat is too thin for the machine to recognize. The nozzle is .4mm
Made lid thicker will try again
