Ah, that makes a difference, just use one rail, switched by the relay, and dedicate it to the bed heater, and the other rail can run the rest. As you say, the worst case scenario will probably be a slower bed warm up.
Sweet. I'll set it up tomorrow and post a picture before I fire it up just so you guys can confirm if I did it correctly or not.
