Results 11 to 14 of 14
Thread: CTC clone help needed
04-16-2015, 07:46 AM #11
- Apr 2015
- 25
OK, Pin to pin is zero volts. Each pin to ground is zero volts. Not connected to anything.
I'll Google the schematic.
04-16-2015, 09:28 AM #12
- Burnley, UK
- 1,662
04-16-2015, 11:58 AM #13
- Apr 2015
- 25
Make sure you get the "old" version of the Motherboard schematic. The old version has the thermocouple wires SCREWED to the hot end. The new version shows the "little bulb" type thermocouples. This is a picture of the extruders on my printer, you can see the screw connection for the thermocouple wires.
04-17-2015, 01:34 PM #14
- Apr 2015
- 25
Mjolinor,
First off I want to thank you for your kind help and support. It is really appreciated.
The new motherboard arrived today, i installed it and it works. I am doing the first "test print" right now. All looks good so far except the "platform leveling" procedure is not the same, quite different. I will call where I bought it from and get some instruction about it.
Thanks again,
Don
