Results 1 to 10 of 21
Thread: Tools of the trade
04-15-2015, 07:23 AM #1
Tools of the trade
What tools, aside from the printer itself, do you use regularly and should be in our essential toolbox? (I'll edit this as it goes to make a comprehensive list in the OP)
- Digital Calipers
- Stainless steel scale/ruler
- Needle File
- Putty knife / Metal Scrapers
- magnifier/loupeLast edited by Marm; 04-16-2015 at 07:47 AM.
04-15-2015, 10:04 AM #2
04-15-2015, 10:17 AM #3
0.25 mm thick flexible steel scrapers.
Got a mixed pack of various sizes from poundland. Best getting-stuff-off-build-plates tools ever :-)
They're in the decorating section for using with crack filler: http://www.poundland.co.uk/flexible-...-blades-4-pack
Acetone
blue tape
pet tape
foam centred sanding blocks - this sort of thing: http://www.amazon.co.uk/FLEXIBLE-SAN...sanding+blocks
Tin snips for cutting plastic filament or plastic - much more useful than scissors. These are more or less what i have: http://www.amazon.co.uk/Silverline-4...ords=tin+snips
m3 nuts - I'd suggest buying a bag of 100. Assorted sizes of m3 bolts. Although this might be makerbot clone users only.
Lubricant - apparently a good gun oil is effective. Also lithium based grease.
Extra allen keys - you will drop and lose the ones that come with the printer :-)
Think that's the stuff I use regularly - with the bits you've already got. The digital caliper and steel rule live in the printer case, so I never lose those :-)
And I really do need to get a cheap set of needle files.Last edited by curious aardvark; 04-15-2015 at 10:28 AM.
04-15-2015, 10:21 AM #4
04-15-2015, 10:30 AM #5
rails, rods, z-screw etc.
Can't remember who suggested it - but it was of the decent printer manufacturers.
04-15-2015, 11:20 AM #6
Ahh. Swear my Taz manual said to never lube anything. Better read it again just in case.
04-15-2015, 11:29 AM #7
- Burnley, UK
- 1,662
04-15-2015, 12:57 PM #8
04-15-2015, 01:47 PM #9
looked at those last time round. But weren't quite as cheap as I am :-)
just bought these: http://www.amazon.co.uk/Sivitec-Need...s=needle+files
Cheap as chips and apparently good quality.
If I want handles - that's what duct tape and pvc tape were invented for :-)
Or maybe just 3d print some if the ducttape is out of reach when I decide I want a handle :-)
Although a base of ducttape with a pvc finish is probably as good as anything :-)
Might print one out of polyflex pla or filaflex for a laugh.Last edited by curious aardvark; 04-15-2015 at 02:02 PM.
04-15-2015, 02:14 PM #10
usb cable extender - so you can have the usb connection in front of you for unplugging and re-plugging. Rather than at the back of the machine or from the computer.
I can even do it one handed :-)
And aputty knife is generally a lot thicker than the scrapers I have. so Not the same thing.
