Thread: Z Steps
04-07-2015, 09:24 PM #1
- Dec 2014
- Canada
- 498
Z Steps
im running into an issue where my models are shorter then expected
when I measured 100mm ends up being 96.31mm
so i was trying to update my Z steps
In Marlin i set it to 6400 steps
but when I connect to the printer, the feed says the following
Steps per unit:
M92 X80.00 Y80.00 Z12800.00 E541.06
Why does it say 12800 steps if i set 6400 steps in marlin
using 1/8 microstep
is it just doubling it since its not using 1/16 micro?
04-07-2015, 09:27 PM #2
- Dec 2014
- Canada
- 498
i tried setting it to 3200 steps and it still shows up as 12800
04-07-2015, 10:19 PM #3
- Mar 2015
- Palo Alto
- 63
Do you have eeprom enabled? Could be remembering the last settings instead of pulling form the configuration.h file.
Code:M502 M500
04-07-2015, 10:33 PM #4
- Dec 2014
- Canada
- 498
I did have eeprom enabled and I think this was the problem. I didnt realize that with eeprom enabled I needed to do M502 & M500 after i flash
i only adjust files in marlin/flash i dont change stuff via the lcd
04-07-2015, 10:43 PM #5
- Dec 2014
- Canada
- 498
Thank you!
04-07-2015, 10:54 PM #6
- Mar 2015
- Palo Alto
- 63
Good luck with your print heights.
