Results 11 to 20 of 102
Thread: Itty Bitty Double FLEX Extruder
04-06-2015, 08:34 PM #11
04-06-2015, 08:41 PM #12
- Mar 2015
- Palo Alto
- 63
04-07-2015, 08:47 AM #13
04-07-2015, 08:54 AM #14
04-07-2015, 09:04 AM #15
04-07-2015, 09:06 AM #16
The nozzles are centered. If you only consider the bed area reachable by both nozzles, which is all you can use for two-material prints, you just lose the spacing width over a single extruder. So with dual, you lose 20mm, and with the flex you lose 27mm--half on each side. If you can physically increase the travel, you may be able to recapture some of the lost space by moving into areas that would have put the single nozzle off the glass.
For a single material print, you typically only lose half the spacing distance, because you can print out to the edge of the glass on one side. In your case, since you have extra glass on the left, if you print with the left nozzle, you may not lose anything.
04-07-2015, 09:07 AM #17
the space is very limited in the left side..
04-07-2015, 09:09 AM #18
04-07-2015, 09:15 AM #19
No, I had it all setup, but when it came time to install the extruder block to the carriage, the probe arm was in the way of the extrduer/carrige mounting hole. I could not get the screw into the hole without removing the servo and arm. Snowball effect...once the extruder was mounted i could not mount the probe arm cuz the hot end was in the way..
04-07-2015, 09:18 AM #20
- Mar 2015
- Palo Alto
- 63
