03-23-2015, 05:56 PM #1
- Jan 2015
- 306
Best way to switch from ABS to PLA?
I just finished a print with black ABS.
I am now printing with white PLA. Black ABS bits are showing up after 3 print attempts. It just wont die. What is the fastest way to clear out an extruder when switching?
03-23-2015, 06:04 PM #2
- Aug 2014
- Montreal, Quebec
- 576
Purge it, turn manually the gear or control it via repetier.
I usually purge 20cm of filament.
03-23-2015, 06:07 PM #3
- Jan 2015
- 306
03-24-2015, 10:00 AM #4
- Jan 2015
- 445
use cleaning filament. run it through, let it cool to 150 or so , pull out the top, 1-3 times of that should clean it out.
