01-20-2014, 01:29 PM #1
- London
- 8
Printing Support Material with PVA
Has anyone tried printing support material with PVA?
http://www.reprapcentral.com/vmchk/M...ypage.tpl.html
Although it's a little pricey, it seems like a great options to print those tricky objects with no flat faces as it would just dissolves in warm water.
01-20-2014, 07:33 PM #2
- Nov 2013
- 67
Pretty interesting stuff. I wasn't aware of this before you posted this.
Here are more details:
Introducing MakerBot® Water Soluble PVA 1.75mm / 1.8mm filament!
This polyvinyl alcohol plastic comes in our custom extruded 1.75mm / 1.8mm filament size. You can just swap the filament from your extruder, and load in the PVA plastic, and then dissolve your parts in water. This plastic builds parts just like ABS, or PLA, and the prints come out a matte white color. It's one kilogram on our heavy duty spool, and ships vacuum sealed with desiccant.
We call this filament an "experimental" plastic, because your extrusion temperatures will be different (160-175C) from standard ABS settings, and you should make sure not to bring it to ABS melting point temperatures. Please read the below instructions and adjust your machine prior to use. There may be some tweaking of your settings for optimal output. When complete, the parts can then be dropped into cold water to dissolve.
Make sure to read the usage instructions and warnings on the MakerBot Water Soluble PVA Wiki page
MakerBot have come up with a few uses for water soluble components at the BotCave, and the possibilities are amazing! Some of the applications include: making soluble molds, building removable support structures, biotechnology applications, or fascinating science experiments of your own creation. We love introducing products like this, because inevitably, the best uses will come from you! Send us your ideas and your results, we'd love to see them! This plastic is off white- and smells a bit like white craft glue.
The science behind MakerBot® Water-Soluble Polyvinyl alcohol:
• Melt flow index (190 oC, 2.16kg); 1.5 – 3.5 g/ 10min
• Melting point; 160 – 170C
• Glass Transition Temperature; 45 – 55C
• Specific Heat; 0.4 cal/ gC
• Density; 1.25 – 1.35 g/cm3
• Solubility into water; soluble into cold water
01-20-2014, 08:05 PM #3
- new jersey
- 752
in theory its great and works but from what i have heard from people that have used it its very tricky. its also a big pia to store it. you have to remember that moisture dissolves pva so on a hot humid day the stuff goes bad just while the spool is setting on the machine. controlled climate is an absolute must.
01-21-2014, 01:18 PM #4
- London
- 8
A mold you'd only like to you use once, I'm not convinced.
The appropriate releasing agent does a prefect job in most cases.
None the less I might have to give it a go as support materials, I'll report back once I have!
