03-16-2015, 11:02 AM #1
- Nov 2014
- Brevard, NC
- 182
Anybody looking into making this sub $30 3d scanner
I have decided to give this a shot. I have ordered most of the parts & knew the cost would be a bit more than he says. I am up to $63 in parts except for the metric nuts, bolts & alum. extrusion. I will probably not start working on putting this together for another month. Maybe by then their will be better instructions on how to put this all together. I ordered some parts from Amazon & some from ebay. The nano board I opted for one that had all the pins soldered which only boosted the cost by $10.
http://www.thingiverse.com/thing:702470
Here are the links to the parts I ordered if anyone has an interest in these. Some of these may have changed price since I bought them.
$14.99 Lucksender ATmega328P Nano V3 Controller http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
$3.40 Uln2003 Stepper Motor Drive driver stepper motor controllers 5V 4-phase 5 line http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
$14.93 5pcs 650nm 5mW Red Laser Line Module Focus Adjustable Laser Head 5V http://www.ebay.com/itm/251688838898
$9.99 Hercules 4780733 HD Twist Mini Webcam - Turquoise Blue Edition http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
$6.92 10 624zz 4x13x5 bearings http://www.ebay.com/itm/10-Bearing-6...item35cf4c9850
-David
03-16-2015, 10:05 PM #2
- Feb 2015
- 211
03-17-2015, 08:25 AM #3
Even with the commercially made scanners from makerbot and others, the quality of what you get scanned and printed is not good. I was watching a video review of one unit (Tested, I think?) and they were pretty excited that you could just barely tell the bust they printed was the same person as the original model they scanned. Cool project for research and learning if you're not counting on high end printed results.
03-17-2015, 09:08 AM #4
- Nov 2014
- Brevard, NC
- 182
I am not sure how well it is going to work, but did seem like something I needed to do for some reason. I think with the low cost of materials, it will get a lot of people interested in dabbling with it & maybe improving it. I am going to wait & print the plastic parts until I am ready to start working on it. This design may change some before then. I actually only spent about $50 so far, & not the $63. I had included the aluminum extrusion in that cost. I might redesign the parts that use the misumi extrusion 2020 to use openbuilds v-slot instead using openscad. I am not familiar with the 123design that his original files are in. I came across this blog yesterday about the other DIY scanners http://bill-owens.blogspot.com/2015/...ng-piclop.html
I was going to look into making the Ciclop scanner mentioned in this blog, but does not seem like he has released enough info to put it together yet.
03-17-2015, 12:21 PM #5
The good news is there is a lot of room for improvement and development.
