03-13-2015, 02:52 PM #1
Create Flexible 3D prints By Putting Wires into the Rigid Material
The team at Filimprimante3D spent just a short time watching the ‘small revolution’ being caused by flexible filament before they decided to add their own twist to it. They noted that while the flexibility is a big plus, the applications of the filament were actually limited as the 3D printing material could be pulled and flexed but then then reverted back to its original shape. Making a simple but genius modification, the Filimprimante3D team designed a 3D model with a shallow trench in the middle so that the 3D print could be stopped to insert a thin metal rod. Once inserted, the 3D print continued so that the rod was encased in the middle and allows the material to be manipulated into a modular form that ‘stays put.’ Find out more about their process in the full story: http://3dprint.com/50977/filimpriman...lexible-print/
Below is a gif showing a flexible 3D printed piece:
