Results 31 to 40 of 41
Thread: Lead screw upgrade
02-28-2015, 07:30 PM #31
- Dec 2014
- Canada
- 498
I will update my stl files and post for all to enjoy
02-28-2015, 10:44 PM #32
- Dec 2014
- 28
That all looks great, good job! I'm looking forward to your results.
03-01-2015, 09:39 AM #33
- Dec 2014
- Canada
- 498
I wired up so two endstops are connected to the same plug into the rambo
but now neither seem to trigger it.. I dont understand why..
they should each operate independantly.. they are not in series
03-01-2015, 10:19 AM #34
- Dec 2014
- Canada
- 498
ok, i figured it out.. looks like th Microswitches are on when not pressed and off when pressed. so I rewired them in series, and all is right in the world
03-01-2015, 10:21 AM #35
- Dec 2014
- Canada
- 498
Stepper steps changes from 4000 to 2560 in Marlin with the M8 Lead screws are 1.25mm per rotation, vs .8mm per rotation
im thinking of getting a 5:1 or 4:1 geared stepper
do you guys think it will make any difference
i would turn off microstepping in marlin this way
03-01-2015, 11:02 AM #36
- Nov 2014
- 522
you would also have more torque to handle the weight of the X carriage and it would take a lot of the strain off of your motors... you might still use microstepping, but only 1/4 as a 4:1 ratio using 1/4 microstepping would technically give you 1/16 microstepping... but i don't know how marlin would handle that unless there were an option somewhere to set that you are using a geared stepper... that's a subject that needs further review... but it's a thought either way
03-01-2015, 11:54 AM #37
- Dec 2014
- Canada
- 498
I have updated my files and posted them here
http://www.thingiverse.com/thing:704091
03-01-2015, 01:54 PM #38
- Dec 2014
- Canada
- 498
I think you would simply adjust the steps.. and change the microstepping
no other adjustment should be necessary
03-01-2015, 02:15 PM #39
- Dec 2014
- Canada
- 498
would it matter if i went with a geared nema 23 vs a 17
im not concerned about the torque. I just want it to be super accurate
http://www.omc-stepperonline.com/gea...pg4-p-145.html
03-01-2015, 02:27 PM #40
- Nov 2014
- 522
i thought about that after i posted that just now got back to actually say something :-P
higher gear ratios are more important for accuracy, but torque is also important to be able to move the carriage... a nema 23 would just add even more torque
