Results 41 to 50 of 113
Thread: PEI Sheet for Bed Adhesion
02-20-2015, 02:51 PM #41
- Jan 2015
- 48
OK succes at bed at 120 and ABS at 250
Thanks for the input!
02-20-2015, 08:50 PM #42
I just installed PEI on my bed and ran my first print, a simple 20 x 20 calibration cube and had no problem at 230/85 with ABS, specifically Hatchbox ABS in Black.
02-21-2015, 10:16 AM #43
Sooo... Does the PEI sheet make noise while warming up and cooling down for anybody else? Mine makes a popping/cracking noise and it kinda freaks me out.
02-23-2015, 08:43 AM #44
I haven't heard anything from mine. I print my ABS at 235 and the bed at 110, I can do smalller objects with the bed at 90, but I get lifting on the corners if I don't have the bed up. I have also taken to using a 60watt light to light up the bed and to also give heat, as my printer is near a window. I have blue makerfarm 1.75, and Orange hatchbox ABS. On a side note, I have had the makerfarm filament jam, and the printer just goes on printing air, I am thinking I run into random thicker spots or bumps in the filament.
02-23-2015, 10:21 AM #45
- Jan 2015
- 48
no noise here. Mine isn't taped to anything. I am just using about 8 clips to clip it to the glass that is above the heat plate.
02-26-2015, 12:30 AM #46
Has anyone tried printing polycarbonate on PEI or buildtak? I have a roll, but could never get it to stick to anything.
02-26-2015, 07:54 AM #47
Over at the SeemeCNC site, where I first found out about PEI, I did a searth through the thread and found that the original thread poster mhackney in a post about his PEI install says "It's a GREAT choice for PLA, ABS and polycarbonate. I've run enough prints of all three of these to be comfortable with it."
02-26-2015, 07:59 PM #48
- Jul 2014
- Eastern Colorado
- 536
I was able to get one print out of my buildtak sheet before the second print started just a hair too low and ruined it. Would the PEI sheet be any more forgiving, or is it also sensitive to first layer height?
02-26-2015, 09:25 PM #49
02-27-2015, 08:39 AM #50
- Jul 2014
- Eastern Colorado
- 536
Plastic extruded too close and "smooshed" into the PEI sheet doesn't bother it?
