Results 1 to 9 of 9
02-24-2015, 05:48 PM #1
- Feb 2015
- 21
Bad surface texture on PLA print.
I have had a bad print with PLA, what is meant to be smooth has turned out very bumpy and rough. Any causes for this? any solutions?
As you can see up Groot's body, it is very rough and it is meant to be smooth.
02-25-2015, 08:46 AM #2
- Jan 2015
- 306
try printing slower, it has fine/thin details.
02-25-2015, 08:56 AM #3
- Feb 2015
- 21
02-25-2015, 09:02 AM #4
- Jan 2015
- 306
Thats a little fast for such a tight part like that. Depends on what type of printer you have. A high precision machine could do it. I would go down to 15.
02-25-2015, 09:12 AM #5
- Feb 2015
- 21
02-25-2015, 09:17 AM #6
How are you getting on with the CTC 3d printer?
02-25-2015, 09:30 AM #7
- Jan 2015
- 306
When all else fails, print slow. It allows you to really see what is happening and diagnose failures. It is also the easiest first variable to remove from the equation because it is just a click of a button to implement. If it still happens, we can go from there. Hope it helps.
02-25-2015, 09:31 AM #8
- Feb 2015
- 21
Great thanks for the help, I'll keep you updated.
02-25-2015, 09:56 AM #9
- Feb 2015
- 21
It's my first printer and I've only had it a few weeks! It's been good so far, no problems with the printer itself just my settings that I have had to tweak. Like warping issues, extruder not hot enough, too fast etc.
Dual extrusion I can't get to work though, gets very messy and when I researched it I found it's a bit of a gimmick? and near impossible to get a decent print?
