Results 1 to 10 of 10
Thread: Hot End Wiggle
02-13-2015, 02:20 PM #1
Hot End Wiggle
All,
I have taken note of some "wiggle" on the hot end.
Should I be using a spacer or something between the mounting plate and the hot end to hold it more firmly? I expect this must have some impact on print quality.
02-13-2015, 03:19 PM #2
Hexagon? I've always felt mine fits pretty loose on the aluminum grooved plate. I used to try adding some kapton as fill in the channel between the hot end and grooved plate, but that's pretty hard to get consistent. On my last extruder build, I kept adding layers of wide kapton to the round end of the hot end, trimming it for the OD of the hot end and the filament hole. Took quite a few layers before I felt the hot end was held firmly. I'll likely print some spacer disks of different thicknesses and use one of those the next time I have the extruder all apart.
02-13-2015, 03:28 PM #3
Kevin,
Yes, that is exactly what I was referring to. Mine seems pretty loose, I will experiment with printing some spacers and see what happens.
02-13-2015, 06:39 PM #4
- Nov 2014
- 138
02-13-2015, 06:52 PM #5
- Feb 2015
- 70
Has anyone noticed any quality issues? Or are we just being proactive in attempting to fix this?
02-13-2015, 07:14 PM #6
Personally, I was proactive starting with the initial build of my printer. I just figured there was no way that having a loose-fitting hot end would *improve* print quality.
02-13-2015, 09:04 PM #7
- Nov 2014
- 58
i had the same issue with my hexagon . for some reason my extruder seems to fit better if i flip the metal plate . so the grove will be facing down . i know its not the correct way to install it but hey.. it worked for me.
02-14-2015, 01:43 AM #8
- Feb 2015
- 211
I put a .015" plastic shim inbetween the hotend and the extruder base and it got rid of the wiggle. I cut the shim circular and put a hole in the center for the filament to feed through.
02-14-2015, 03:10 AM #9
Guys, here are some "washers" to help. I made them in three thicknesses so you can see which works best for you.
http://www.thingiverse.com/thing:682001
02-14-2015, 07:18 PM #10
- 9
