Results 1 to 10 of 19
Thread: Heated bed insulation
12-29-2014, 12:19 PM #1
- Dec 2014
- Canada
- 498
Has anyone used this to provide insulation under there heated bed?
12-29-2014, 02:15 PM #2
- Nov 2014
- 522
ooh youll have to let us know how it works... i'm using cardboard
12-29-2014, 04:32 PM #3
12-29-2014, 06:45 PM #4
- Jul 2014
- Eastern Colorado
- 536
I, too, am using cork.
12-29-2014, 08:37 PM #5
I have cork on the underside of my heated pad, and two layers of aluminium cooking foil between the heated pad and the glass sheet.
OME
12-30-2014, 03:45 PM #6
- Dec 2014
- Canada
- 498
why did you decide to add the alum foil under the glass?
01-05-2015, 07:46 AM #7
Hmm looks like an interesting product to try. I would be a little concerned that it is normally used to insulate pipes from a cold environment instead of being heat resistant. The concern being the product may melt when introduced to 110C, but it is worth trying out to see!
02-03-2015, 10:33 AM #8
What thickness is the cork you guys are using?
Robert
02-03-2015, 10:54 AM #9
- Dec 2014
- Canada
- 498
02-03-2015, 05:05 PM #10
I put the aluminium foil between the heatbed and the glass to try to ensure that they were both in contact with a heat conductive medium. Aluminium conducts heat a million times better than air.
OME
Aluminium (or aluminum; see spelling differences)
