Results 1 to 10 of 16
01-22-2015, 09:51 AM #1
RepRap Central Announces 2015 3D Printer Challenge
Imagine a 3D printer which features rapid build times, super smooth vertical operation, incredible accuracy, and super quiet operation. The team at RepRap Central, a UK merchant dedicated to the RepRap community, are asking you to take on the challenge of engineering and possibly building just such a machine. They call the idea an FLM printer, or Fused Layer Manufacturing, and the winning entrant will need to complete one full layer at a time using only the vertical Z Axis. You can read the whole story here: http://3dprint.com/39021/reprap-central-flm-challenge/
Let us know if you have entered this contest and feel free to post details of your entry below!
01-22-2015, 01:13 PM #2
- Jan 2015
Dlp
Don't DLP based resin printers already do a complete layer at a time? Granted DLP may not be as fast but they do handle one layer at a time. Resin is also expensive so I guess it would depend on what the additional details were.
01-22-2015, 01:53 PM #3
Collaboration ?
Very interesting indeed. If there are any interested parties (businesses or individuals) willing to start a conversation (could lead to a project?) then please get in touch with me at scott.knowles @ objectform . co . uk
Thanks
01-22-2015, 03:01 PM #4
- Apr 2014
- 228
It seems pretty sketchy when their page doesn't explain what it really is or how it works. It reads like a common marketing ploy of an advance announcement to pump up some hype.
I know Boyer is in it, I would have hoped that he would be better than that.
01-22-2015, 05:50 PM #5
I admit, i had to read the full post at couple of times to understand what Dr. Bowyer is looking for... and it would be a game changer. DLP resin based printers and FFF printers work in essentially the same fashion. In fact they all do. The material is hardened or extruded at a single point (x,y,z) at one moment in time. What the good doctor is hoping to find, is a method by which an entire layer (z) is laid down at a single point in time. As ObjectForm said, "very interesting indeed".
I'd be looking to simplify this by first handling two axes at a time, either X || Y && Z. That in itself would be an order of magnitude faster.
And that's all i'm going to say at this point
(Edit: My bad, DLP printers do work differently)Last edited by truly_bent; 01-22-2015 at 06:07 PM.
01-22-2015, 05:57 PM #6
- Apr 2014
- 228
01-22-2015, 06:06 PM #7
You're right JRDM. Thanks for straightening me out on that.
01-22-2015, 09:48 PM #8
It does sound very much like a DLP printer, except if their plan is to extrude a layer at a time having millions of little nozzles pushing out hot plastic. Why would you go through that complexity to have so many more parts that can fail?
Yes a DLP projector itself does contain more parts than a complete FDM printer, but to a DLP printer a DLP projector is just one component that can be replaced easily. It is a component that is proven to be stable and usable for many hours at a time without needing replacement.
Resin isn't as expensive as it used to be. You can get it at $65 per litre. Your failure rate with DLP is much lower than with FDM so your mileage will be alot better with 1L of resin than it is with 1kg of filament. I have kilograms of failed ABS prints in bags sitting in the garage.
01-24-2015, 12:17 AM #9
- Jan 2015
01-24-2015, 12:35 AM #10
- Jan 2015
