Results 1 to 10 of 42
Thread: so what causes this?
01-21-2015, 07:03 AM #24
On the holes and notches in thin sidewalls, yes it is on both the inside and the outside. Whether it is on a corner, a hole, a notch, outside or inside, it's always on the right hand side looking at an upright surface. At least on my small test print, I know that's the exit direction of movement.
In other words, it's not that the same ripple is showing up on both sides of an extrusion. I should point out that with at least the test print I'm currently using for this, "thin wall" is still fairly thick - it's 1.75mm. I'm seeing Simplify3D use three passes for this 1.75mm wall.
