Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Staff Engineer printbus's Avatar
    May 2014
    Location
    Highlands Ranch, Colorado USA
    Add printbus on Thingiverse
    New editing restrictions?
    I was trying to add a few sentences to an old post here - http://3dprintboard.com/showthread.p...ll=1#post17771. I get a vbulletin pop-up that says my message is too short - that it has to be more than 10 characters. Like I said, I had added a few sentences, so I was already adding more than 10 characters... Got the same error on reattempting the edit.
    EDIT: The exact wording of the pop up is "The message you have entered is too short. Please lengthen your message to at least 10 characters."
  2. #2
    May 2014
    Location
    Further experimenting indicates posts that originated more than about four months ago can no longer be edited. Maybe that restriction has always been there, and I'm just lucking into editing posts that old. If that's the way it is, should the EDIT POST option still be appearing?
  3. #3
    Staff Engineer old man emu's Avatar
    Oct 2013
    Location
    Narellan, New South Wales, Australia
    I'd just create a new post and make reference to the original one you wanted to edit.
    OME
  4. #4
    May 2014
    Location
    Quote Originally Posted by old man emu View Post
    OME, I understand that as an alternate solution. It'd still be nice to understand whether there's a new time duration allowed on post edits. On other boards, users lose the option to edit after a while. Here, vbulletin is coming up with a message that makes no sense. That's my main issue.
    A concern I have in just adding a new post is that for something like the printer build thread linked to in the original post, it isn't exactly helpful to add say post #160 that states, hey, what you read back in post #30 was wrong, and here's what you should have done in your build instead.
  5. #5
    Senior Engineer
    Jun 2014
    Location
    Burnley, UK
    As far as I know it has always been there. I found it the same way about 6 months ago.
  6. #6
    May 2014
    Location
    Just got the same vbulletin message attempting to edit a post that was created TODAY.
  7. #7
    Administrator Eddie's Avatar
    Sep 2013
    Location
    Cape Coral, FL
    Follow Eddie On Twitter Add Eddie on Facebook Add Eddie on Google+ Add Eddie on Shapeways Add Eddie on Thingiverse
    Hmm perhaps users aren't allowed to edit messages. I will have to check into this.
    Eddie
  8. #8
    May 2014
    Location
    Quote Originally Posted by Eddie View Post
    Eddie
    Thanks for looking into it. Something is going wrong. If it helps, the post I created today and immediately could not edit is this one - http://3dprintboard.com/showthread.p...ll=1#post44061. I still can't edit that post. I can bring up the edit window, but get the vbulletin popup regarding too few characters in the message when attempting to save changes.
    There are other posts I've recently added, and other old posts that I've recently edited, that I can still edit fine. The issue seems almost random - that some posts can be edited and some cannot. And again, the vbulletin message that says a message is less than 10 characters when attempting to save the edit makes little sense.
    EDIT: This post, for example, I can edit fine.
  9. #9
    May 2014
    Location
    Can I suggest that a moderator attempt to edit either of the posts I have provided links to and report back on the results?
    EDIT: Nevermind. See the next post.
  10. #10
    May 2014
    Location
    OK - here's more info. It turns out I could edit and save both of those sample posts, but I had to go into the advanced mode to do so.
    At least now I know there's a work-around to whatever the issue is.
