Results 1 to 10 of 107
01-12-2015, 02:07 PM #10
Thanks, just saw the notification pop up. I hope to have a video up on installation/use of it later this week but was busy printing misc stuff this weekend. I too had the same issue of getting the thermal barrier tubes out after the set screw leaves its mark. The set screws really gall things up. On my original flashforge parts I ended up drilling out the mounting hole a little, but this doesn't do anything for heat transfer at all since only a sliver of metal to metal contact is left after the set screw pushes the tube forward in the hole.
One of the most important things to do when putting this new system on is getting the thermal tubes nice and smooth again. This will help insure that the tubes slide up and down easily when the clamps are loosened. I have been using the system for a couple of months now with no issues. Periodically check the clamp bolt to make sure it is tight.
