01-04-2015, 04:06 PM #1
- Jan 2015
- 19
Getting some curling on the bottom corner of some blocks
I am doing 9 small blocks on my Replicator 2 using PLA. I am getting some curling on the bottom, one or two corners. It is Makerbot PLA. The painters tape is brand new. Thanks for any advice.
https://www.dropbox.com/s/ujak0cwr0c..._0151.JPG?dl=0
Steven Houtzager
01-05-2015, 08:13 AM #2
- Lehi, Utah
- 26
use helper disks (aka pac man corners, mickey ears)
01-05-2015, 08:23 AM #3
- Jan 2015
- 19
01-05-2015, 03:01 PM #4
- Lehi, Utah
- 26
go to Thingiverse and search: helper disk and pacman corners .... for examples
basically you are putting a thin round disk on the corners, they will pull up and curl, hopefully keeping your square corner down
01-06-2015, 12:27 AM #5
- Dec 2013
- Chiloquin Oregon
- 36
When I am having lifting problems, sometimes the mickey ears helps. If its really lifting then sometimes I also pause the print and masking tape down the ears! One of my gremlins was my drafty shop, once I closed off the side of my machine that problem went away, hurray! Russ
