Thread: Test cube problem
12-23-2014, 10:31 PM #2
#1, test cubes should always be printed 100% solid. There is no real reason to deviate from this. Most likely those were printed without enough support and the top sagged.
Print a cube at 100% infill, .2mm layer height, 60mm/s feed rate, 100mm/s travel. 235 temp for abs, 200ish for PLA.
Then snap a picture of it.
