12-12-2014, 11:19 PM #1
Post mentions laser cutter for around $250
Can someone point me to a recent post which mentions a small laser cutter attachment that sells for about $250? I want to read a bit more about it as I might buy myself one as a Christmas present.
OME
12-13-2014, 05:40 AM #2
- Burnley, UK
- 1,662
I don't remember a post about an addon but the only one that sells for around that is the small thing made out of CDROM hardware.
http://www.aliexpress.com/item/Promo...805621759.html
You can engrave with them but they won't cut tissue paper.
No way would I consider a 3D printer a suitable place to stick a laser with enough power to cut unless you stick the start button on the outside of the room and have a safety switch and movement detectors in the room.
This was a one watt laser, typically for the sort of wood used in the Replicator frames you need at least 40 watts.
http://www.laserpointersafety.com/ne...97e677-206.php
Forty watts goes through soft tissue like butter.
I bought one off ebay for £80 needing a tube, £112 for a tube and have spent the last couple of weeks fitting Ramps to it.
12-22-2014, 03:07 PM #3
- 462
L-Cheapo laser cutter attachment. Uses a 2 watt blue laser diode and is specifically designed for attaching to a 3D printer. I've yet to attach mine as I want to build an enclosure first.
http://robots-everywhere.com/re_site/purchase/l-cheapo/
12-23-2014, 12:37 AM #4
El Cheapo! That's the one I was looking for. Thanks for replying.
OME
12-23-2014, 12:53 AM #5
- Nov 2014
12-23-2014, 06:19 AM #6
