Results 1 to 10 of 74
Thread: i3v 12" build log
12-15-2014, 07:42 AM #10
- Aug 2014
- 24
I ran into the same issue with the LCD adapter over the weekend. I ended having to enlarge a couple of holes on the white controller board just to get the bolts to fit through. I also used some of the longer bolts as I thought there was too much stress on the board as well.
Not sure if you gotten this far or not, but another issue I had was with mounting the Rambo and the heat bed relay. The edge wooden plate that the rambo board mounts on, once mounted to the frame, comes right next to the holes to mount the relay. It was so close that the edge pcb of the relay would hit the bottom lip of the rambo's wooden frame. I took a look at the build video up close and noticed the bottom edge of my wooden plate was shaped differently compared to the one in the video. I didn't want to cut the wooden frame as I already had it painted so I created some spacers and used those to mount the relay. I would be interested to know if you found a better way to handle this.Last edited by razer1141; 12-15-2014 at 09:24 AM.
