Results 51 to 60 of 232
11-26-2014, 04:12 PM #51
- Jul 2014
- Eastern Colorado
- 536
Now all we need is some way to remotely clear the print bed of a finished print so another print could be started. I've had thoughts of a servo-actuated "blade" mounted to the back side of the lower X vslot that could be flipped down after a print to scrape it off the glass.
This has been discussed several times on the OctoPrint requests page, and from what I understand, it would tax the RasPi too much to do continuous polling of the extruder position. The RasPi doesn't keep track of position, it would have to continuously ask the printer where it is. Doing that while it's sending movement commands to the printer seems to be too much.
11-26-2014, 06:43 PM #52
12-09-2014, 10:20 PM #53
- Apr 2014
- 50
Hey, what do you have as your Axis mm/min settings? (Settings > Printer Parameters > Axis)
I don't want to over-tax my steppers by issuing commands that will fry them.
12-10-2014, 07:09 AM #54
- Jul 2014
- Eastern Colorado
- 536
X: 3000, Y:3000, Z:200, E:540 I took the values from Marlin and put them in here.
12-10-2014, 07:45 AM #55
OK, I'll bite. What settings in Marlin are these? DEFAULT_MAX_FEEDRATE? If so, aren't the stock values 15000, 15000, 120, and 1320 (adjusted for mm/min)? Interestingly, your values for Z and E aren't far from what my initial experimenting with motion related settings suggested. You've seen the other thread for sharing improvements to the motion settings, right?
12-10-2014, 06:49 PM #56
- Jul 2014
- Eastern Colorado
- 536
Yup
Code:#define DEFAULT_MAX_FEEDRATE {250, 250, 2, 22} // (mm/sec)
edit: huh, I guess I didn't get the numbers from Marlin after all. I don't remember where they came from, then. Maybe stock OctoPrint?
12-10-2014, 09:46 PM #57
I don't think OctoPi defines those parameters. It does have some motion related but IIRC those are only for the interface jog, not printing.
12-12-2014, 09:25 AM #58
- Jul 2014
- Eastern Colorado
- 536
Nearly panicked last night, thought my OctoPrint had suffered a major bug, and I didn't know what to do to fix it. I could load the page, see the webcam, everything. I could upload any .gcode file I wanted. But I could not load or load/print the file. The buttons were faded. The only solid black button was the Trash button. I don't know how many times I rebooted the RasPi, or how many times I restarted OctoPrint.
Then I hit on the brilliant idea of refreshing the web page. Success!
*headdesk*
I've said it before... I'm dense.
12-15-2014, 08:41 AM #59
Haha I know this struggle! "Why can't I click the buttons! Oh I need to login again for some reason..." I like the *headdesk*
12-17-2014, 11:03 PM #60
- Jul 2014
- 64
I have been reading through these posts and have ordered what appears to be necessary to set up the Raspberry Pi with Octopi. However, it is not clear to me if this eliminates the need for the kit lcd display or not? I do understand that a display is required to access the Raspberry Pi.
New member with print issue
