Results 101 to 110 of 172
11-29-2014, 09:05 AM #101
- 114
Here's a quick link https://www.youtube.com/watch?v=7WSa06m263Q
11-29-2014, 09:24 AM #102
Well... 2 or 3 things were on the list to make you happy.... But I suspect you want your LCD Panel to work the most.
I don't have an LCD Panel, but I wanted to use the M600 Filament Change command those people wrote to promote the LCD Panels. So I had to add a couple of routines to provide functionality that the LCD Panels normally provide.
First... Save your entire code base before you make any changes. Probably you won't be able to make this work first try and we don't want to lose forward progress.
First, go into Marlin_main.cpp and delete this code. These are the duplicate routines that you wont need:
Code:// Roxy substitute routine to provide user confirmation easily on a PrintrBoard. // It looks at GPIO PC1 pin 11 value for input value change. // This routine looks for a button press to confirm everything is OK. // This allows the firmware to provide the Filament Change feature without // an LCD panel installed. The switch is wired from the Expansion Port 2 // header pin closest to AT90USB1286 chip to a switch that can connect it to // Ground. #define FILAMENTCHANGEENABLE #ifdef FILAMENTCHANGEENABLE #ifndef ULTIPANEL bool lcd_clicked() { int pin_being_examined; int ii, iii, jj; pin_being_examined=12; // This is PC1 on PrintrBoard pinMode(pin_being_examined, INPUT_PULLUP); // Set it to Input with a pull up if it hasnt delay(50); // been used since RESET. iii = digitalRead(pin_being_examined); // Get the current state of pin. return !iii; } void lcd_pressed() { while( lcd_clicked() != 0 ) // Wait for the switch to be released ; delay(50); while( lcd_clicked() != 1 ) // Wait for the switch to be pressed ; delay(50); } #endif #endif
11-29-2014, 09:50 AM #103
- 114
Here is the error when compiling after above changes.
Marlin_main.cpp:3404:35: error: missing binary operator before token "No"
Marlin_main.cpp:3836:15: error: missing binary operator before token "No"
11-29-2014, 09:56 AM #104
- 114
Question for you. After g29 the z raises, where did you set this?
11-29-2014, 09:57 AM #105
11-29-2014, 10:00 AM #106
Probably, you are talking about this code at the very very end of the G29:
Code:do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS] + Z_RAISE_BETWEEN_PROBINGS); #ifdef Z_PROBE_SLED dock_sled(true, -SLED_DOCKING_OFFSET); // correct for over travel. #endif // Z_PROBE_SLED retract_z_probe(); } break; #ifndef Z_PROBE_SLED case 30: // G30 Single Z Probe
11-29-2014, 10:04 AM #107
- 114
Marlin_main.cpp
Here it is.
11-29-2014, 10:12 AM #108
I don't see a problem.... I know it is a pain... But I guess you better .ZIP up your current code base so I can run the whole thing through the compiler and see the problem first hand.
I'm sure what ever is wrong is simple and not a big deal... But I don't see the problem by going to those lines in the source code.
11-29-2014, 10:17 AM #109
- 114
Marlin_Roxy_V2.rar
Okay, it's attached.
11-29-2014, 11:06 AM #110
There is something funny going on with the C++ Pre-Processor. It is having trouble doing casts on the BEEPER token. And it is defined properly in Pins.h as 36. I have to run out the door. How about you revert back to your previous firmware until I figure out how to convince Arduino that the code is OK? Incidentally... The code it is barfing on hasn't been changed from the main branch of the tree and has been in there since the UltiPanel was released. So it is a little strange it is having issues with it now. There must be something else factoring into the equation.
