Results 1 to 10 of 12
11-24-2014, 03:55 PM #3
Just make sure your ABS is as low printing temp as possible, or close to the PLA as you can. If you print on one side at say 180c and the other at 230c, you will see some serious issues (like plastic being heated up again after cooling down, which can cause those crappy lifting corners on the sharp edges, top layer... but if you can get it around 210c for the PLA and 225c for the ABS, it's a good mix.
As for supports, yep, as said above this is your program, not your printer. Switch to something else and give it a go.Hex3D - 3D Printing and Design http://www.hex3d.com
