11-15-2014, 09:08 AM #1
Make Your Own 3D Printer Extruder
Egypt-based ATOM 3D is an open source project for DIY 3D printers. The project has released an Instructables tutorial on how to create a simple, low-cost extruder for a 3D printer. Using everyday materials like plywood and aluminum scrap, the extruder looks simple to put together and seems to work. Check out more details in the full article: http://3dprint.com/25029/atom-3d-diy-extruder/
Below is a look at ATOM 3D's DIY extruder. Let us know if you have tried doing this project. Leave your feedback, suggestions and comments below!
11-16-2014, 09:12 AM #2
- Apr 2014
- 228
Looks good. I would suggest getting the barrel top as close to the drive pulley as possible, and a filament guide hoop above the drive as well. The less gap between the barrel and the drive means less opportunity to buckle the filament. A filament guide hoop would help contain filament position before it goes into the drive. Maybe just surface glue instead of tab into slot, to avoid weakening the lever arm.
