11-08-2014, 05:01 AM #3
Anything UNDER 0.4mm will fit, so yes they will do fine, the E and B string anyway... These are perfect for the 0.4mm nozzle on my flashforge. The 0.3mm is on my kossel - but I use it for both.
There are even lighter gauge strings you can buy, yo just want cheap light gauge strings.
maybe... not sure how rigid it is - the reason I use guitar string is because it wont bend easily when you poke it up there
here is a cheap set of strings... $2.16
http://www.ebay.com/itm/6-Pcs-Silver...item19f18d5991
4 of Them will be useless (unless you play guitar and the other two will last you the lifetime of your printer.Hex3D - 3D Printing and Design http://www.hex3d.com
