Results 1 to 10 of 172
10-30-2014, 06:29 PM #4
- Aug 2014
- 627
See, I just ran into an instance (prior I thought the same way you do) where I need to do this because if I want to multicolor print using a single extruder with the old code you just can't
Thank you so much and I will try this in a few days as Halloween is here and I am busy busy with fixing an ancient mechanical skeleton butler/decorations and doing family things.
