Results 451 to 460 of 757
10-22-2014, 07:11 AM #451
- Jul 2014
- Eastern Colorado
- 536
I uncommented the two EEPROM defines in configuration.h, and removed my +4 from marlin_main. Compiled and uploaded, sent a M502 then a M500, then ran G28 through pronterface, followed by G1 Z0. Nozzle stopped 4mm above the bed. Re-commented the EEPROM defines, re-added my +4, and uploaded.
10-22-2014, 10:06 AM #452
No... Not yet... I'm so swamped with other stuff. But for sure, I'll get to it. I need to actually port Dacb's fork to my printer so I have the complete code base. I don't have the limited probe area stuff running on my printer yet.
If nothing else, Old Man Emu might beat me to it because he is bringing up Dacb's Marlin fork on his MakerFarm. And that might be trivial for him to get going.
10-28-2014, 05:42 PM #453
- 114
Roxy
Can you help setting the matrix to eeprom up? I am at this since several weeks but don't get it.
I successfully run a G29 only after reset, un comented the G28 deletion line, and would like the matrix or what ever needs to be stored to be saved to eeprom.
10-29-2014, 11:07 AM #454
- Aug 2014
- 627
I have a question and that is using ABL how would I dual color print (or however many colors) with a single extruder? The simplest way is to have multiple models with each being in its own color (change out the filament before each print) and all is fine but with G28 going to the middle of the printing surface and lowering the hotend to find Z's home the switch would plunge into the previous model.
How can it be done using ABL?
10-29-2014, 12:13 PM #455
Well, If you're using Cura, the simplest would be to use the "pause at height" plugin.. It basically pauses the print at a given height, allowing you to change the filament, and then resume printing.. I know some Cura plugins also allows you to pause at height, move the hotend out of the way of the print, to minimize ooze on the print, prine the extruder with a new filament, and then resume.
10-29-2014, 04:36 PM #456
- Aug 2014
- 627
Strictly a Slic3r + Pronterface user here.
10-29-2014, 05:40 PM #457
10-30-2014, 12:42 AM #458
- Aug 2014
- 627
10-30-2014, 04:49 PM #459
Your wish has been granted: http://3dprintboard.com/showthread.p...trix-to-EEPROM
11-05-2014, 07:31 AM #460
- 114
Never mind just saw the last post!
