Thread: Constant jamming problems
10-22-2014, 07:42 AM #3
+1 to Drone's suggestion.
Just extrude 50-100mm and slow that feed rate down in pronterface to half of the default or more while you manually squeeze the guidler bearing in. If it extrudes too fast you could be getting chewing that your wouldn't normally experience during a print. Once you get a feel for how much tension is needed, start with the bolts loose and it extrude smaller test lengths and tighten the screws down 1 or 2 turns per small test length until you get a good extrusion.
