Originally Posted by
MakerFarm
Connect J2 to one heat bed wire and GND from your power supply. Connect J1 In to 12v+ from your power supply and connect the other heat bed wire to J1 out, then connect the two small Pre-Soldered wires to your Heat Bed out put of your electronics (D8 for RAMPS, Heat bed port for Printrboard etc)
New member with print issue
