Results 11 to 20 of 112
10-10-2014, 11:59 AM #11
Haha, yes, manuals can be useful sometimes
You can print multiple models by selecting them in the Process Settings:
Process Settings -> Select Models (button on bottom of process settings screen)
This way you can use different processes for different parts/models.
If you have multiple processes then it will prompt the following when you want to print:
And then you can either do sequential printing with clearance height (the height it will build 1 object before switch to the next) or continious printing (most used one due to dual extruders & bars being in the way when doing sequential printing)
Good luck!
EDIT: I was using multiple parts / processes here to do some testing with different variables for optimal printing.
EDIT2: Also; always check the print in the 'Prepared Print' windows before exporting because what you see is what you get! If you only see one part; then you'll only get one part - so go back and change your settings and Prepare your Print again!
Makerware works perfect too! The only reason I switched to Simplify3D is for the custom supports & ability to add different processes (and doing layer-based settings.. and some other stuff ... )
If you have any questions about Makerware then we can probably help you too, else try the Makerbot subforum on this board!
Good luck to you too!
10-10-2014, 01:17 PM #12
Ah - right, never seen those selection screens. You'd think when you've got more than one model on the bed it'd ask you if you wanted to print them all.
So I have to apply a seperate process to each model ?
10-10-2014, 03:34 PM #13
You can go to the model selection screen of the Process Setting and press 'Select All' to select all models (and print all models with that single process).
It normally adds all models to the first process for me, unless I start adding more processes; then it of course needs to know what model to print with what process.
So... no, you don't need a separate process per model - you can print select whichever models you want and add them to whichever process you want.
It's not that difficult; you'll get used to it quick. Just make sure you always look what happens in the Preview mode - because what you see is what you get!
(I usually scroll through the model by selecting the 'END' scroll-thingy and dragging that quickly from begin to end to get a good idea of how it will be printed.)
10-11-2014, 05:55 AM #14
- 13
10-11-2014, 06:09 AM #15
cheers guys :-)
I knew this thread was a good idea :-)
10-11-2014, 07:26 AM #16
- new jersey
- 752
You would be amazed at how many options there are in s3d that are staring you right in the face but are skipped right over without noticing. The select models has to be the biggest one.
10-11-2014, 07:32 AM #17
Okay you're going to love thisd if you haven't already tried it.
The add-in option has a thing called 'convert image to 3d'.
And it does !
You have to save your picture - anything from a photo to a simple shape in a png or bmp file. jpg/jpeg does not currently work. But any photo program from paint on up will save in png format.
It then converts to a 3d stl file and re-imports the file for tweaking. Play with the z xis scaling to get it the height you want and print. Currently trying a koala head (windows sample pics) at 1mm height and 0.2 layer.
Looked good in the preview.
And this works with ANY picture.
I'll be making dog head coasters later :-)
10-11-2014, 12:31 PM #18
10-12-2014, 05:56 PM #19
- 349
So was it found that it could vary the infill by X-Y, if you have different models?
10-13-2014, 01:30 AM #20
Hi 3DPBuser, can you explain what you mean?
If you are asking if different infill patterns are possible then: yes and no.
The only infill pattern possible in Simplify3D is straight lines.. BUT you can choose at which angles these lines are placed and in which orders these angels come up.
Standard is -45 & 45 meaning you're getting a cross-pattern. But if you prefer to place these lines horizontal and vertical then that's possible to by using 0 & 180. OR you can go funky and do it 'hex' like by using 0 & 60 & -60.. so a lot of options depending on what you want, but a 'true' hex pattern like in Makerware is not available in this software.
