Results 1 to 8 of 8
09-04-2014, 05:58 PM #1
BigRep PRO - 53 Cu Foot Build Volume
I have a thing for large 3D printers, I admit. BigRep who earlier this year unveiled an enormous FDM printer called the BigRep one, has just announced an even more robust machine, that's an incredible 8 cubic feet larger then it's last 3D Printer. The BigRep PRO features a build volume of 53 cubic feet, allowing for the printing of furniture pieces. The machine is estimated to retail at around $79,000. More details on the this new massive 3D printer can be found here: http://3dprint.com/13906/bigrep-pro/
Below is the very first available image of the new BigRep Po 3D Printer. What do you guys think?
09-04-2014, 06:43 PM #2
53 cubic feet sounds big - but 1.5 cubic metres doesn't
What are the ACTUAL print dimensions ?
Volume measurements are just confusing.
And what does it print with ?
Sounds pretty cheap for the size too.
09-04-2014, 09:16 PM #3
- Apr 2014
- 228
Is that a photo or a rendering? Is it really that hard to have a product web page ready when a press release is posted? I doubt the specs are in flux.
09-05-2014, 03:46 AM #4
Well... must be a Hell of a long print to use this kind of volume. I'll be impressed when they release an announcment of several heads working on it in harmony.
09-05-2014, 11:34 AM #5
Ah but for volume that size you'd most likely use a much bigger nozzle and much thicker layers than a small desktop model.
10-10-2014, 08:02 AM #6
10-10-2014, 08:16 AM #7
- Dec 2013
- Georgia
- 934
The way I always use to keep the volume scales right in my head is that a cubic meter of water (de-ionized, at sea level yadda yadda) is by definition one ton.
I don't know about you, but for some reason it's easy for my mind to visualize "if this were a pool, how many tons of water would fill it?"
10-10-2014, 10:54 AM #8
Well having seen a printer with 1x1x0.5 metres
1.17x1.17x1.17 is pretty big :-)
