Results 1 to 10 of 13
09-25-2014, 09:41 AM #3
Yes, once the bed level correction matrix is generated... All coordinates given by the GCode get translated to the new coordinate system. Check out:
http://3dprintboard.com/showthread.p...ll=1#post27846
The original code took 3 points. If you want to do that for legacy reasons you can. The 3 point plane is still in the firmware. But right now the firmware is doing an n x n grid and taking a least squares fit to determine the new coordinate system.
There is work in progress from some of the people here to automatically limit the n x n grid being probed to the size of the print on the print bed. This will help accuracy.
